Long warmup.
Old Nov 1, 2003 | 01:41 PM
alarsso44's Avatar
alarsso44
Long warmup.
I think my 1996 F150 5.8 E4OD takes too long before the motor reach the right temperature and it use a lot of gas during this time, especially now when outside temp drops. My 82-250 400-motor warms up much quicker. I have not checked the thermostat yet, but could it be something else? What exact is the purpose of that short tube between thermostatehouse and waterpump? Looking forward to some ideas.
Old Nov 1, 2003 | 10:50 PM
stevieray's Avatar
stevieray
I believe it is a bypass hose, that is it bypasses some coolant when the thermostat is closed untill the engine warms up. Your problem could be that the T-stat could be stuck open so it takes a long time for the circulating coolant to heat up. The reason for the T-stst is to hold most of the engine coolant in the block until it warms up to the prescribed temp then opens to prevent it from over heating.
