FE engine
Wanted
Engine - Complete
  • Closed
  • Price
    Any Price
  • Location Chelsea, MI, 48118, USA
  • Condition New or Used
  • Compatibility
Make Model Year
Ford F-100 1965 - 1977
Description:
Looking for an engine in the Michigan area (or relatively close to there). I would prefer a running 390. really looking for a long block that has been upgraded or rebuilt recently without problems or issues. I would be interested in the larger 406, 410, 427, 428 engines as well.
Old Dec 24, 2021 | 04:43 PM
ChaoticMN's Avatar
ChaoticMN
Running 352
I have a complete running 352 long block with the following parts included.
2 barrel carb rebuilt Spring 2021 from Rock Auto
Water pump new Spring 2021
Fuel Pump New Spring 2021
Truck Motor mounts
Petronix point less distributor and coil
Direct 4 blade fan w/ extension. Original 66
Flywheel with clutch still attached.
Truck exhaust manifolds
Have video of last drive a month ago, engine runs good I'm just build a 428 to replace it.
Compression is 135 on one cylinder and 115 on the two lowest cylinders Speedo is at ~ 75000 miles
I'm asking $1500
Last edited by ChaoticMN; Dec 24, 2021 at 04:49 PM. Reason: forgot to say it's a 352
