1966 Running 352 FE from a F100
For SaleEngine - Complete
Description:
Great for a 6 to V8 swap
Complete running 352 long block with all the following parts included.
2 barrel carb rebuilt Spring 2021 from Rock Auto
Water pump new Spring 2021
Fuel Pump New Spring 2021
Truck Motor mounts, Perch’s are extra$
PerTronix pointless distributor, coils and wires
Direct 4 blade fan w/ extension and single pulley
Flywheel with clutch still attached
Truck exhaust manifolds still attached
Have 3 video’s of last drive in Nov 2021, engine runs good I'm just building a 428 to replace it.
Compression is 135 on one cylinder and 115 on the two lowest cylinders. Didn't have a gauge for oil pressure just the dummy light and it works.
Some parts not in pictures come with it, listed above.
