Timining Questions
Old Jul 25, 2000 | 08:17 PM
ramboss429's Avatar
ramboss429
Timining Questions
I have a '92 F-150 4x4 with a 302 in it. I would like to know what the factory timing is supposed to be set at? Also if I would advance the timing what should I advance it to?
Does advancing the timing add any mileage, power, etc? I heard it did but don't know for sure.
Old Jul 25, 2000 | 09:21 PM
nitro94's Avatar
nitro94
Timining Questions
Timing is 10 deg. BTC with the spout disconnected. Spout is a small plug looking device that is taped to the wiring near the TFI module on the distributor. Remove this plug and you are in base timing mode (no computer control). Set timing and reinstall plug so computer can do its job. I would not recomend that timing be advanced beyond factory specs. as other undesirable problems are usually created.
Old Jul 25, 2000 | 09:27 PM
Pastmaster's Avatar
Pastmaster
Timining Questions
The spout connector is on the drivers fender well by the diagnostic hookups. I have a 1989 F-150 that I set at 14BTDC and I noticed a little more throttle responce and a little more pinging under WOT.
Pastmaster's 1993 XLT 5.0 E40d 3.55LS Normal Cab/Long bed Loaded from the factory with aid of...MSd 6a ign/s.p. wires, blaster coil, Hypertech Chip, K&N filtercharger, Cat-back dual exhuast w/o mufflers, 3.5", echo tips, Accel distributor cap, Actually the spouk Mocha over light mocha. 5% Dark tint, Alpine Cd player/remote, Pioneer speakers.
Old Jul 25, 2000 | 10:16 PM
nitro94's Avatar
nitro94
Timining Questions
