Aftermarket Steering Wheel
My OEM steering wheel is in pretty bad shape so I'm shopping around for an aftermarket replacement. I see that there are lots of "Universal" fit type steering wheel with 5 or 6 bolt adapters. I'd like to get a system and the right adapters that looks good installed without any huge gaps in the steering column. Looking for recommendations from anyone that has a system they like and any pics if you have them.
TIA
Mike
TIA
Mike
As long as you are OK with Black, Dennis Carpenter makes the OEM style from original tooling. They are currently out of stock but you can get them at a few different places for a slight markup although it can be tough to know if they are resold DC or an junk repro. I know you mentioned you wanted to but I wouldn't go aftermarket. Without the OEM bits, turn signal and turn signal cancel, horn etc are a pain and gimmicky.
https://www.dennis-carpenter.com/tru...-black-3-spoke
If you can wait, I'd keep an eye on this link to go back in stock...or try and find a good one at a junk yard.
The following users liked this post:
Foreversharp.com has an excellent collection of steering wheels that will fit your truck and using their adapter it will bolt right up and everything works as it should.
The video is for a dent but their B-03 adapter will work on your truck.
https://fssteeringwheels.com/collections/half-wrap
Connecticut Calvin
07-23-2015 03:32 PM
N2Cardiology
10-09-2011 08:28 AM
J1MMY
04-16-2009 01:27 PM
