I’m interested in ordering a 2022 F-250 Lariat FX4 Supercrew. I test drove one with both the blackout and sport package this combo missed fitting in the garage door by 0.5”. Curious if anyone with a similar truck with the 18” wheels could measure the height to the rear satellite antennas? Thank you in advance.
Seems like you should have just enough with a standard 7' door opening. I have a 22 F-250 Lariat Super Cab 4x4 with the 18" wheels on order and the Ford specs show 81.4" for the height. That may not include the radio antenna but the radio antenna won't keep the truck from coming through the door opening. I went to the dealership (on a Sunday when they were closed) and measured several F-250's earlier in the year when they still had inventory and they all were right at the factory number. I'm really counting on mine fitting in the garage. That's way too much money to have it sit out in the Florida weather!
Not sure how the truck had both the Black and the Sport appearance packages...but that doesn't matter, what it did have is 20" wheels/tires (unless the truck was actually a Tremor). The 18" wheels come with tires that are 1-2" smaller diameter than the 20" wheels, depending on A/S or A/T. In theory that should make a similarly equipped truck with 18" wheels at least .5" lower.
