Sponsored by: Real Truck
Iac?
Old Nov 1, 2003 | 08:50 AM
orucco's Avatar
orucco
Iac?
I have a 2000 SD250 V10 Manual 5 speed with 56k miles that is starting to die when you come to a stop at times. Is this a symptom of an IAC valve problem and if it is can I attempt to clean it before replacing it............Thanks.
Old Nov 1, 2003 | 12:18 PM
jaxf250's Avatar
jaxf250
Yes, could be IAC but more often IAC shows up when trying to get it started in the first place. Could also be a clogged fuel filter among other things. With 56K miles I think you are overdue for a replacement if you have not done so already.
