I need help finding the correct pcm for my truck. 88 F150 4x4 manual 5 speed 4.9. IDK if it helps but it has a year 94 engine, and it was an automatic when I bought it.
Calibration Code: 7-52E-R10 E8AE-6E061-ACD
Any help would be greatly appreciated. I've learned a lot from this site the past few months, finally found a problem I was forced to ask about myself.
The Ford part number for that Calibration Code is E8TZ 12A650-BSA.
This is for a 4.9L EFI engine.
Note this not the number that may be on the part but the Ford part number.
Keep in mind, it's not imperative that the replacement PCM match exactly what was originally in the truck. I've run a number of different calibrations in my truck without any noticeable difference. Just make sure you get one from a '87 - '94 4.9 w/ manual transmission. I've found even the 4x4 or not doesn't have any noticeable difference in running.
I've got a few spares if needed. A couple I have listed on eBay under ID Alfa-164, but feel free to contact me off-line.
