Reverse issue
Old Aug 13, 2021 | 07:09 AM
bishop10's Avatar
bishop10
Reverse issue
02’ Explorer. When I put it in reverse going straight back it doesn’t automatically start to roll. When I give it gas there is a grinding noise and it feels like I’m running over something and then it rolls smoothly.
When I have to turn the wheel while reversing the grinding last a little longer.
What’s the issue?
Old Aug 15, 2021 | 08:31 AM
shorod's Avatar
shorod
The 5-speed automatic transmissions in the Explorers (as well as a few other models) are known for shift solenoid issues that effect reverse. You're probably looking at needing a new shift solenoid and possibly needing to have the case drilled and sleeved to fix the issue. If there's a transmission shop in your area that you trust, they can likely give you a pretty accurate estimate to repair as they've probably done several.
-Rod
evan1242
Aug 7, 2015 02:43 PM
texas_rebel21
Mar 24, 2009 02:20 PM
ponyrider
Escape & Escape Hybrid
Dec 7, 2008 09:20 AM
jford98
Dec 12, 2002 11:30 PM
