Radio/Touch Screen help 2016 Lariat
Two days ago I turned my truck off normally and opened the door. The radio did not turn off. I am so used to the radio turning off when I open the door, that it definitely got my attention. I pushed the radio power/volume ****, but the radio stayed on. I then got out, shut the door, and locked the doors. I opened the door, and the radio was off. I stepped on the brake and started the truck with the push button. The touch screen was blank, and the radio did not come on. I shut the truck down and restarted a couple of times, but the screen remained blank and radio off. After doing some google searching I: pushed the radio power button and right seek button together for a reset with no success, checked all the fuses related to the radio and Sync and all are good, disconnected the battery for 10 minutes with no success. I have since driven the truck several times, and the screen remains blank and the radio off. Has anyone experienced this issue? Bad APIM? What else should I try? Thanks!
The following users liked this post:
