Sealing stake pockets...
Aug 8, 2021 | 07:53 PM
How are you guys sealing the seams where the stake pocket laps onto the bad?
I was planning to use 3m heavy bodied seam sealer...but Im not sure if it is sandable?
So do you guys have something you use?
Do you tape and smooth them?
Aug 9, 2021 | 08:43 AM
I cheated...
I bought a new bed from Midwest Early Ford and the pockets aren't cut into it.
Aug 9, 2021 | 08:57 AM
Quote:
Originally Posted by
bjmayberry2
I cheated...
Mine neither...
Im referring to the seam where the tube is spotted to the bedside.
Aug 9, 2021 | 01:31 PM
I’m not sure what you’d use, but that seam sealer is like concrete when it cures. You might have success with J-B Weld.
Aug 9, 2021 | 02:22 PM
Aug 10, 2021 | 05:55 AM
I don't completely understand your question about the stake pockets and the need to seal them but I can answer your question about the 3M heavy body seam sealer. Yes, you can sand the cured seam sealer...it's like sanding a hockey puck. I use this product exclusively on the roof drip rails to replace the OEM sealer.
Aug 10, 2021 | 11:57 AM
These are the areas I am referring too. Does it seal up fine after being sanded?
Aug 10, 2021 | 11:58 AM
So you guys don't seal those seams?
Aug 10, 2021 | 05:19 PM
I don't seal those seams...but if I were to attempt it I would use some KBS Rust Seal and do my best to work it into the gaps.
Aug 14, 2021 | 05:28 AM
Guess it depends on the look you want. The horizontal seam, I would weld closed and grind. Looks like you know what you are doing there with welding. For the vertical, I would leave it but depends on what you want.
beehunt
Dec 15, 2019 07:51 AM
ZOOT
17
Aug 14, 2015 06:27 AM
02GrayPowerStroke
Jan 23, 2010 12:30 AM
Stingray42
Paint & Bodywork
Nov 23, 2003 08:58 PM
