Heater hose assembly replacement
Has any replaced the heater hose assembly. Coming the the return off the heater core, the rubber hose connects to a metal hose that runs underneath the intake manifold to the back of the water pump…. Mine has two rusted holes in it and is leaking bad…..
has anyone replaced this and do you have to remove the manifold to get it off/on?
Where the return from the heater core connect on the back of the motor
Where it runs under the manifold
Where it connects to the water pump
