New air cleaner
Old Aug 7, 2021 | 11:15 PM
kegger66's Avatar
kegger66
New air cleaner
I had recently installed a Holley Demon carb and it's design wouldn't allow me to use the OEM air cleaner so I had to come up with something else that didn't just pull hot engine air in (that would have been the easy way out)
Before - It's on there but was binding the choke lever (dang it!)
I ran it down to where the OEM air inlet was next to the radiator. The air plenum came in polished aluminum so I did the right thing and ...
...sprayed a little Ford blue on it and stamped it with the (not from '78) 400 2V sticker.
Parts: this was the Spectre 743 (Single Air Plenum kit) -https://www.spectreperformance.com/743-spectre-plenum-kit
I did modify the air plenum so I could run the hose from the back valve cover into it (similar to how the OEM setup was). I'll post a pick of that detail when I get it finished up (I've just got the hose jammed into a hole I drilled in the plenum, working on a OEM-ish solution for it)
Old Aug 7, 2021 | 11:24 PM
redroad's Avatar
redroad
"Old Red" is looking good Kraig ! Those are some great upgrades
Zulder
May 23, 2023 02:26 PM
leonharu
Oct 15, 2021 07:56 PM
harley7991
Jul 5, 2021 08:31 PM
rbettis888
May 30, 2021 10:47 PM
mike01082
Oct 29, 2010 01:17 PM
