I'm not sure what Speedway or Macs is selling, but according to Ford, they are different pumps using different repair kits. This is assuming the OP has a factory original pump. Googling the part number of the kit, A7A 9349 A only turned up this page of the catalog.
At our altitude, with ~2.5 psi or more lower atmospheric pressure, and the lower vapor pressure of gasohol, an electric pump was my choice to avoid vapor lock. Especially on a 226, the fuel line has plenty of opportunity to pick up engine heat as it winds its way around the engine compartment. I run an Airtex pump, it has been very reliable. If you are 6v, you'd want a p/n E8902, if you're 12v an E8016S. Either can be run without a regulator, they are 2.5 - 4 psi output. Made to last on gasohol, too.
Thanks for that info. The truck is at 8200’ so it might be even more relevant but then again it’s run for a long time on the stock pump and I’d like to go that route.
I may run both, I’ve done that on another old car where I use the electric just for starting to prime the carbs.
The Airtex 592 seems to be the same as the Airtex 578 (V8 fuel pump) excepting the actuating mechanism, hence why places these days sell the same rebuild kit for the 6 and V8.
Edit: What a rabbit hole you sent me down researching this all! Quite enlightening for myself.
Need to be cautious doing so as the electrical fuel pump acting on the mechanical pump can cause the diaphragm in the mechanical fuel pump to silently fail and pump your crank case full of gasoline for a very expensive mistake.
If you look at the attachment to 52Merc's post, the catalog says the diaphragms are different. You would think Ford would use the same part but it appears they didn't.
Everywhere I looked for electrics or repair kits the story was the same: "On National Back-Order"....
Thanks for your effort but C & G doesn’t have it when you try to buy it, neither does Summit.
Ford part numbers, their revisions, insignificant differences, and cataloging are a mess. I would just about guarantee a modern Airtex 592 will fit the bill. If you replace the whole pump, the diaphragm that is included is going to be just fine.
You can try looking for an old Airtex 9786 there as well - it is very similar to the 592. However, one of two those likely has different inlet/outlet threads than the other (don't know what your truck has), but can be converted to what you need with brass fittings or with new lines. With out finding a new/re-manufactured pump, you are rebuilding your existing or purchased core. The L6/V8 rebuild kits mentioned early on here are likely to work on the critical internals for any of these, especially since Macs states it fits (call them and clarify) and there are seemingly no other real options out there.
I just went through this on our 49 straight 6. The V8 kit worked for our truck. Only issue we have is the check valves on our pump seem to be in the casting (aftermarket pump I assume) so was not able to replace them. They weren’t leaking so I just replaced the springs and diaphragm. Runs like a top again. Reuse your arm and pin, because ours was slightly smaller than the one that came with the kit.
