will dynomax headers fit?
Old Oct 31, 2003 | 06:43 PM
CodaSmog's Avatar
CodaSmog
I bought a set of dynomax headers off ebay a couple of months ago and I'm gettting ready to install. I wanted to make sure they would fit before I took off the old rusty ( bolts are going to snap) manifolds. the number on the headers are (602 57) I have a 1975 F-100 with a 77' engine any advice would help. Thanks alot
Jeff
Old Nov 1, 2003 | 10:27 PM
CodaSmog's Avatar
CodaSmog
I see that a couple of people have looked at my post with no replies, I forgot to tell you that it's a 2X4 hope this helps. I've read other post about jacking the engine, not that it's a big deal but I want to know what to expect.
Old Nov 2, 2003 | 07:45 AM
seventysixer's Avatar
seventysixer
I just bought a set and if I get the old manifolds off I will find out. problem is that mine is a 76 with a big block. I can't see why you have to do a lot of things, like why does eveyone say the passenger side is the hard side when the drivers side looks like it will have all the issues, but everyone says the same thing so they can't all be wrong
I would think it would be lots easier with the small block, but the only way to find out is to jump in and give a whirl. Good luck.
Old Nov 2, 2003 | 08:55 AM
Sanddoc's Avatar
Sanddoc
should be no differenct for the engine year
both are 302...
go for it.
did you check for the numbers say for
the 302 in a 77 truck?
Best
