93 chevy truck seat installed
I picked up a 93 chevy truck seat Friday from a salvage yard for $100. It does need to be reupholstered, but that was expected.
It fits really well but the only problem I have is the lh bolts , because I'm using the stock gas tank, the bolts aren't easy to get to.
I was able to get the rear bolt in from underneath by the braille method. I was able to get my hand between the tank and cab enough to push the bolt up through, while my wife put the nut on from inside.
We didn't try to get the front one, because I'm going to pull the seat anyway to get it redone. My wife might be able to get to it from the gas sender inspection hole. If not, I might have to cut a hole in the floor close to the bolt hole to access it.
I really don't want to pull the tank out
It sits nicely into the back of the cab & gives me quite a bit of leg room.
I tried to get to bolt from the inspection hole but my hand is to big.
Received 4,216 Likes
on
on
I had the same seat in the beginnning and had to raise it up about 2" to get it right for me... got buckets now and it's much better
https://jniolon.classicpickup.com/be...enchseats.html
john
john
The following users liked this post:
on
john
john
Buckets are out because she wants to sit next to me like when we started dating in it.
May 30th 1976
Looks great!
Have you considered rivet nuts or "nutserts"? Similar to the hood bolt repair kits MidFifty and others sell:
(3) How to Install Rivet Nuts, Nutserts, Rivnuts - Street Beast '66 427 Cobra Replica Hood Catch - YouTube
giffenf
01-14-2019 04:28 AM
df85732
07-27-2016 07:41 PM
J Selman
07-10-2003 08:32 PM
