TTB seals
Old Jul 22, 2021 | 11:02 AM
quincyj34's Avatar
quincyj34
TTB seals
I'm in the process of rebuilding a ttb out of a 95 bronco for my truck and im not sure which seals for the spindles I should go with. On rock auto they list for auto locking hubs and manual. The axle came with factory auto hubs but I am converting to manual hubs, so which spindle seals do I go with?
Old Jul 22, 2021 | 01:27 PM
GoinBoarding's Avatar
GoinBoarding
Are you referring to wheel bearing seals, or the smaller seals in the back of the spindle that seal to the axle shaft?
In the case of wheel bearing seals, 1995 was a design change year, the seal went from a single grease seal to a two piece seal, and for whatever reason a different diameter spindle on the sealing surface. I wasn't aware lockout spec had any impact on which design was used though.
Old Jul 22, 2021 | 01:34 PM
quincyj34's Avatar
quincyj34
The seals on the back of the spindle. I've seen 13144 for the outer and 18844 for the inner referenced a lot but they list for manual hubs, I've also seen the bk1 kit referenced but that list for the auto hub. So is it asking which hub came factory?
I am also looking at rock auto for the part numbers they list.
PSDlongbox
Mar 2, 2013 11:30 AM
brandonmartin
21
Feb 9, 2012 01:20 PM
davelength
Offroad & 4x4
Dec 4, 2009 03:47 PM
youngfordguy
Bronco II
Nov 16, 2006 05:52 PM
Berlinetta00
Offroad & 4x4
Apr 3, 2004 10:34 AM
