2005 Expedition P2272
Old Jul 22, 2021 | 09:02 AM
jeff80's Avatar
jeff80
Truck had some coil/plug codes. I fixed those by changing out coil after some troubleshooting. Now P2272. I do sometimes get a little stumble/hiccup at speed under load (50-60mph). I also have the startup/hot idle noise which is probably the Makeuloco cam phaser stuff. Truck has 98k. Probably saw a lot of idle time as it was a county/police vehicle. New O2 sensor is on the way I will probably swap the 2 downstream sensors and see if fault follows to be sure it’s the sensor.
thanks for your input!
Jeff
Old Jul 23, 2021 | 03:30 PM
pdqford's Avatar
pdqford
Any exhaust leaks upstream of the driver’s side downstream O2 sensor?
Jhodge37067
Aug 5, 2020 08:42 PM
htodac
Modular V8 (4.6L, 5.4L)
Dec 29, 2016 12:25 PM
mcboudreaux
Jul 12, 2012 11:23 PM
gangstasoulja305
Jun 16, 2009 09:05 PM
bonnievom
25
Feb 25, 2008 05:22 PM
