Sponsored by: Auxito
Third brake light problems,still!
Old Oct 31, 2003 | 09:13 AM
BlueOvalFitter's Avatar
BlueOvalFitter
Angry Third brake light problems,still!
Well,ive had to replace another burnt third brake light bulb again!This makes 4 in three weeks! Can anyone guide me to the problem? There is no water in the lens area,and ive used bulb grease in the socket.Those wires are pretty bunched up;could one be frayed?Where do I start looking?Where is this socket grounded? Help!
Old Oct 31, 2003 | 06:05 PM
Racerguy's Avatar
Racerguy
What brand of bulbs have you been using?
A frayed wire shouldn't cause your problem.
The ground is behind the passenger kick panel.
Old Oct 31, 2003 | 06:37 PM
BlueOvalFitter
I think ive fixed it; the bulb was very loose in the socket so I closed the probes of the socket a bit and on the bulb,pulled the contact wires out a bit.This made the bulb very tight in the socket.I'll keep ya'll posted!
Old Oct 31, 2003 | 07:58 PM
LxMan1's Avatar
LxMan1
Good luck to ya. Hopefully, that will get it.
Jimmy
