92 ex starting problems
Old Oct 31, 2003 | 09:12 AM
kattdog's Avatar
kattdog
my 92 4.0l ex takes quite a few cranks over in the mornings to start. she just started this. always was pretty quick to catch before. idles fine when she does go but just seems to crank over about 5-10 times now before she catches? what should i checlk and do?
Old Oct 31, 2003 | 09:18 AM
mrshorty's Avatar
mrshorty
1st thing I would check is fuel pressure. The fuel system is supposed to hold pressure for an extended time after the pump has shut off. What sometimes happens is the system stops holding pressure which can cause it to take longer to start.
Old Oct 31, 2003 | 09:23 AM
kattdog's Avatar
kattdog
how do i check and what should i be looking for?
Old Oct 31, 2003 | 06:53 PM
aletheuo's Avatar
aletheuo
Could be a bad IAC... I would recommend checking this before the fuel system. Look for the sticky at the top of this forum on IAC. Very common on fords.
Old Nov 1, 2003 | 04:24 AM
Opera House Works's Avatar
Opera House Works
If electrically inclined
You can jumper out the fuel pump relay as a test. This will keep the pump on instead of just the 3 seconds when you turn the key on. Then a leak won't matter. On pass side of engine is the fuel rail with the regulator. There is a bycycle tube fitting to attach a pressure gauge. I stole a fitting from an old bike pump and attached it to a gauge. With some of these you need to unscrew the valve to get a reading. Pressure should be around 39# prior to starting and 33-34 at idle, hold at least 20# for 30 minutes.
RadioControlGuy85
Feb 2, 2017 10:17 AM
F350AK
170
Feb 20, 2016 02:39 PM
LivingLarge
Nov 25, 2015 11:15 PM
bcompton35603
Sep 25, 2015 10:36 AM
wannaBelkhuntin
Dec 11, 2010 02:02 AM
