Good day gents, I bought my 2017 F250 used. I was told that that the suspension has a mild lift installed. The rear end sits about 2” higher than the front and is pretty rigid; the tongue of my 5th wheel TT only collapses the height by 1-2”.. Is there an easy way to drop the height of the rear by 2”? TIA
Doesn't look lifted to me either, unless maybe an inch up front. Stock my 19 has 3"+ of rake. As suggested, a smaller block will bring the rear down, but also defeats the purpose of it being higher in the first place. If you lower the rear, with your 5th wheel hitched up you will be nose high. Also, it won't have any effect on the stiffness ("rigid") you are feeling.
I read that whole post forum with your comments and I can't thank you and the other knowledgable guys enough for helping me with my decision to go that route!
