Trailer Lights
Old Jul 14, 2021 | 03:08 PM
Louie Klouless's Avatar
Louie Klouless
Trailer Lights
I have a 1998 F150 that I bought last year. I have been towing a travel trailer, and everything is ducky, all lights and trailer brakes (7-pin, round plug). When I hitched up my boat trailer (using a 7-pin round to 4-pin flat plug adapter), only the tail lights work on the trailer: no brake lights or turn signals. Here is where it gets weird: testing at the terminals on the upstream side of the truck plug, I also get no power to the brake and turn circuits. Hooking up the travel trailer again, it still works. How can there be power when the travel trailer is connected, but not at the terminals and when the boat trailer is connected?
Thanks for any help!
Old Jul 14, 2021 | 08:58 PM
Reel Kahuna's Avatar
Reel Kahuna
Check your ground wire
Old Jul 15, 2021 | 07:08 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Do not depend on just the trailer hitch to supply a ground. Use a real wire connection through the 4 way to the trailer FRAME.
Old Jul 15, 2021 | 03:14 PM
FuzzFace2's Avatar
FuzzFace2
So this testing on the up side was this on the adapter to trailer side and not working?
Testing the truck side on the round 7 pin I bet you get power, now plug in the adapter and bet you dont have power.
If that is the case you got a bad adapter.
You can try a different adapter or put a round 7 pin connection on the boat trailer.
Dave ----
steelie green
Apr 15, 2021 03:30 PM
old farm truck
All Things Towing
26
Sep 2, 2017 08:59 AM
oldrifleman
2009 - 2014 F150
Apr 28, 2015 12:17 AM
jonrjen
Electrical Systems/Wiring
Feb 17, 2015 03:55 PM
sublimecharger68
All Things Towing
Aug 7, 2002 10:43 AM
