Rust spot on leaf spring
My truck was built on 6/2. I already have a penny sized rust spot on my driver side leaf spring right where the the rubber grommet attached to the frame would make contact with the overload spring when weighted down.
Is this a common problem? Seems way to early to see rust.
Many folks on the forum touch up any issues on the axles & suspension with black spray paint. Unfortunately it's not uncommon. I had the same issue on my 2020. I assume the leaf springs and axles sit outside somewhere before assembly. If you live in salt country, you might want to consider having the truck sprayed with Krown, Fluid Film, Woolwax, Corrosion Free or similar. I touched up all the axles, etc with spray paint before I had my truck sprayed with Corrosion Free.
The following 5 users liked this post by BillyE:
The following users liked this post:
It is the suspension, a moving part for Christ's sakes. Perhaps you would like it so rigid you would never make contact.
You have a more legitimate gripe about other parts of the suspension such as the front axle that will rust or is not painted at all.
Tired about guys crying about buying an $80,000 truck it's ridiculous. So Upped like.
The following 4 users liked this post by 1olddogtwo:
I bought my truck to pull a 14K dump trailer. I use my truck as a truck. I did wash, clay bar and do a paint correction on it a few weeks ago because I like to keep it clean. I also keep the interior detailed when I can. If I have rust under it on the frame I don't know nor do I care, it will take a few hundred years before it gets to be like the Toyota's where a few years ago.
If it bugs you paint it. 10K or 100K they all rust some place.
The reality is that the chassis, axles, suspension, etc are coated just enough to look nice on a showroom floor or in the dealers lot. They will rust soon after you drive them in the rain the first time. If manufacturers actually made these things to stay "showroom fresh" for 10 years, maybe then it would really be worth $80k.
Search some videos and articles on the new F-150's, Ford seems to be even stingier with the paint under those. Some look like a 15 year old used truck underneath lol.
