Bronco II Ford Bronco II
Rebuild, need computer reset?
Old Oct 30, 2003 | 11:50 PM
csgaraglino's Avatar
csgaraglino
Ok, I just finished rebuilting my 90' and I have NO POWER in the low end. None!
I did change the cam to a RV cam, and ground doen the block for a little more compression, but other than that it's stock parts.
Do I need to do something to the computer the let it knwo that it now running a motor with 175k miles on it any more?
Is there somehting else going on?
Old Oct 31, 2003 | 10:28 AM
Ken00's Avatar
Ken00
Welcome to FTE!!!
The computer would reset after having the battery disconnected.
Old Oct 31, 2003 | 11:36 AM
87 XLT's Avatar
87 XLT
What codes have you pulled?
Old Oct 31, 2003 | 12:32 PM
csgaraglino
Ok, here's what's happening.
When the truck is under a load, ie I'm going up a hill and giving it more gas, or when i just llay into it, it's falling on it's face... Giving me the impressions that it's flooding and can't handle the request?
Any ideas?
Old Oct 31, 2003 | 12:42 PM
87 XLT's Avatar
87 XLT
Maybe the pump isnt delivering enough fuel. Have you checked fuel pressure?
Old Oct 31, 2003 | 12:58 PM
87 XLT's Avatar
87 XLT
Old Oct 31, 2003 | 01:16 PM
csgaraglino
It's going in to put on the computer for diag, this afternoon...
Old Nov 3, 2003 | 06:22 PM
dmc919's Avatar
dmc919
is that a wild raceing cam, if so then you wont get any power till bout 2,500 rpms
Old Nov 4, 2003 | 04:19 PM
csgaraglino
Nope, it's just a RV (Reconational Vehical) cam. It's suposed to change the power band for torque. Givine me better pulling ratios.
It's nothing "high-performance"
Old Nov 14, 2003 | 09:05 AM
csgaraglino
Did finly get all the kinks out. When I talked with Ford they recomended that the factory specs be re-programed back into the computer. That i did and solved most of the issues.
