IAC Pigtail Connector
Old Jul 10, 2021 | 10:28 PM
TexasGuy001's Avatar
TexasGuy001
I'm looking for a weather pack type OEM style connector of the idle air control valve. I found that there is a Standard S683 that appears to be nearly identical to the factory connector, but it seems to be unavailable. I had to settle for the S663 which is a non weather proof basic type connector at least for the time being. Does anyone know where this item can be found or know if you can still get a new Motorcraft one? The Motorcraft ones I saw when searching look totally different. I would be interested in a clean used one if anyone has that. Mine was corroded beyond cleaning up.
https://www.summitracing.com/parts/smp-s683
http://www.oreillyauto.com/detail/c/...+control&pos=5
https://www.oreillyauto.com/detail/c...+control&pos=6
Old Jul 11, 2021 | 06:51 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Ouch. $$
Old Jul 12, 2021 | 04:00 PM
TexasGuy001
Dang that is kinda pricey, but may be worth it. I didn't see that on Rock Auto when searching for IAC parts.
Old Jul 12, 2021 | 11:57 PM
AuroraGirl's Avatar
AuroraGirl
Did you search under electrical connectors or electrical components
because connectors almost always have their own tab which is nice
it would also be nice if Ford didn’t use proprietary ones because even tho monopolies over stuff suck a lot of auto makers use Delphi connectors and it makes it nice for finding used ones or new ones on the cheap. As well as connector repair kits being affordable.
Old Jul 16, 2021 | 11:23 PM
TexasGuy001
Searching Rock Auto under electrical connectors for IAC only shows the S663 which is the basic style connector. You have to search under Idle Speed Control Motor Connector to find the WPT1057 Ford part.
Old Jul 17, 2021 | 04:11 AM
My4Fordtrucks
Yep. You can see that in the header of the picture I posted the other day.
MBuckholz
Nov 12, 2024 05:43 AM
timmerk
Apr 13, 2020 09:02 AM
THE BLUE HEAP
51
Oct 6, 2016 08:52 PM
BigD_ca
2009 - 2014 F150
Jul 10, 2015 11:48 PM
karter81
Apr 4, 2015 09:27 AM
