check engine light....easy fix?
Old Jul 7, 2021 | 09:00 AM
KBMWRS's Avatar
KBMWRS
2017 F250 6.2L gas
52k+ miles
So the engine light (shaped like the engine) lit up yesterday. check manual and of course it says take it to the dealer.
Is there an easy fix to this? Of course if it is serious I'll take it in.
Thanks
Old Jul 7, 2021 | 09:03 AM
BSHORT's Avatar
BSHORT
Top Answer: 5
Try pulling the code......
Old Jul 7, 2021 | 09:05 AM
C12H24's Avatar
C12H24
It could be one of a thousand things. The "Check Engine" light just means that something that affects the engine emissions is out of specification. It could be a loose gas cap, a misfire, or something like a failed mass airflow sensor. If you do some research on OBD II codes, you will see a very long list of codes. And without hooking up a scan tool, you will not know which of those codes turned on the light.
Old Jul 7, 2021 | 09:24 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Easy fix for the light is to cover it up so you can't see it anymore...
Old Jul 7, 2021 | 09:27 AM
Ding126's Avatar
Ding126
usually gas cap or mas air flow sensor. BUT thats only a guess without a code
Old Jul 7, 2021 | 09:37 AM
KBMWRS's Avatar
KBMWRS
Thanks to all who offered constructive answers. I do not have a scan tool so that is the start of not having an answer.
To the others with just flippant responses....just don't type. Everyone will be better for it.
Old Jul 7, 2021 | 09:40 AM
KCoulter's Avatar
KCoulter
Many auto parts stores will pull codes for free if you don't have a scan tool
Old Jul 7, 2021 | 09:57 AM
C12H24's Avatar
C12H24
Yep. They will do that. The other thing they might try to do is diagnose your problem and sell you a part. What is not widely known is an OBD code saying the HSO2 sensor is out of range is just giving you bad news of something amiss further up stream. Not many codes are actually smoking guns. A failed HSO2 heater circuit is usually a failed heater in the sensor, but it could also be a fuse problem from a grounded heater circuit. It happens. That's why you have to go through the diagnostic steps. I wonder how many HSO2 sensors were sold in an attempt to fix a high or low reading?
To the OP, I would take Coulter's advice and get the computer scanned and write down the code(s). Let the forum know as a follow up on this post what the codes are. You might get lucky. You never know.
Old Jul 7, 2021 | 10:07 AM
Split rims's Avatar
Split rims
I agree. Go to an auto parts store and get the codes and post back here.
Old Jul 7, 2021 | 10:37 AM
GABAR's Avatar
GABAR
It could be something serious or simple but the CEL came on for a reason.
Just stroll down to your local auto parts store and let them scan it for free or purchase a scanner so you can read the codes yourself and go from there.
Old Jul 7, 2021 | 10:42 AM
BSHORT's Avatar
BSHORT
Top Answer: 5
Just go to a shop...your problem is now solved.
Old Jul 7, 2021 | 10:56 AM
minke's Avatar
minke
Some indicated faults are transient. Hope for one of these.
Some codes can merely be cleared, but I don't know enough to give you any advice.
Old Jul 7, 2021 | 11:09 AM
C12H24's Avatar
C12H24
Don't clear a code. It doesn't fix any problem and you not only remove the code, but you also destroy the freeze frame data. The freeze frame data is a lock of all of the sensor data at the moment the computer turned on the MIL. A technician needs to see that data in order to assist in a diagnosis. If the fault that turned on the MIL -a transient condition you reference- no longer exists, like maybe a cylinder misfire and the plug clears up, the computer will turn off the MIL after a couple drive cycles. The code will be moved to history and the freeze frame data will still exist. The benefit here is that the computer can still be scanned, the tech can see the code that set the MIL and see the freeze frame data.
The only time I clear a code is after I've fixed the issue that set the code.
Old Jul 7, 2021 | 11:19 AM
minke's Avatar
minke
Thank you.
Old Jul 7, 2021 | 11:28 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Ask a silly question, get silly responses.
