Transmission wire assembly external harness.
Old Jul 2, 2021 | 02:14 PM
1FORDLEMMON's Avatar
1FORDLEMMON
Trailering
Does any body have a part # for the outside transmission harness from the trans to the Computer. i have a 2004 f250 Vin date # 03/04
My truck is Shutting off on the freeway and while at idle randomly. when it happens the Glow plug light and wtf light come on pretty sure i have a short some where causing the pcm to reset its self i have auto ingenuity scanner every thing looks fine. truck does not set any codes. i have replaced the engine harness a few sensors both glow plug harness replaced the ficm from ficm repair.com. im totaly lost at this point im going to try and replace the fuel injection harness when its back in stalk and try a trans harness since its leaking at the plug ill fix the leak just need the part # for the trans harness. thanks my fellow 6.0 friends.
Old Jul 2, 2021 | 03:28 PM
TooManyToys.'s Avatar
TooManyToys.
Discontinued by Ford.
Old Jul 2, 2021 | 04:48 PM
Hartwig's Avatar
Hartwig
Did you checked power to PCM ?
Old Jul 6, 2021 | 10:25 AM
Erik727's Avatar
Erik727
That harness for a 2006 4x4 is 6C3Z-15525-PA.. Don't know if its the same for your truck.. I bought this harness from Ford in summer of 2018
xcrsp440
May 1, 2017 11:12 PM
Jacob90
Mar 24, 2017 09:36 AM
mtnchap
May 11, 2015 11:36 PM
farmerash
May 11, 2014 07:14 PM
pjerrn
Mar 5, 2013 06:51 AM
