Obd1 code scan process
Old Jul 1, 2021 | 09:37 AM
IowaVulcan's Avatar
IowaVulcan
I need to check the codes on my 91 F350. The link in the tech info is not working, can someone shoot me a link to a working description of the whole process. I know the basics but I don’t have a manual to make sure I follow all the steps.
thanks all
Old Jul 1, 2021 | 09:54 AM
Conanski's Avatar
Conanski
Do you have a code reader?
Without a code reader, insert a jumper wire (paperclip) between the Self Test-In and Sig RTN pins on the EEC TEST connector found under the hood behind the air filter box.
Then turn the key to run and count the flashes on the check engine light. You can cycle the key as many times as necessary to get the correct count.
Old Jul 1, 2021 | 09:59 AM
IowaVulcan's Avatar
IowaVulcan
No code reader, thanks for the quick reply, I wasn’t sure which pins to jump, so I thank you for the visual!
Old Jul 1, 2021 | 10:11 AM
torq'ta 5 8's Avatar
torq'ta 5 8
Fuel Injection Technical Library » How To Run a Self-Test
yours will be 2 digit codes-->Fuel Injection Technical Library » 2 Digit Self-test Codes 11-32
Old Jul 1, 2021 | 06:51 PM
kevinv10's Avatar
kevinv10
Also make sure motor is warmed up. And ALL accessories are off, lights, radio, heater.
Also pay attention to the codes. You will only get 3 digit codes.
Old Jul 1, 2021 | 07:41 PM
rla2005's Avatar
rla2005
A 1991 may display 2 digit codes. You have to be careful counting flashes or invest in a code reader.
Old Jul 1, 2021 | 09:39 PM
Conanski's Avatar
Conanski
The code reader that takes all the guess work out of it doesn't cost very much... INNOVA 3145: Ford Code Reader For most 1982-95 Ford/Lincoln/Mercury Vehicles | JEGS
eric777
Sep 18, 2006 06:55 PM
beeglej
Oct 27, 2005 08:25 PM
93candycane
16
Sep 30, 2004 03:21 PM
pman26
1983 - 2012 Ranger & B-Series
Jan 16, 2004 04:12 PM
Pastmaster
Jun 20, 1999 11:36 AM
