Stuck in park
Old Oct 30, 2003 | 05:36 PM
ivsleptsincethen's Avatar
ivsleptsincethen
Stuck in park
I have a 84 f-150 that has decided not to leave my driveway. For some reason the shifter will not come out of park.
Any ideas?
Old Oct 30, 2003 | 06:17 PM
fishmanndotcom's Avatar
fishmanndotcom
The shifter cable could have broke or your park gear is broke....one is really cheap and one is real expensive.
good luck man
-jason-
Old Oct 30, 2003 | 09:47 PM
locknkey's Avatar
locknkey
If you are stuck on an incline...mebie you need to see if you can rock it out...but other suggestions Might be pauseable...but you had to park it right? So try the least expensive route first...then go for the glory of fishin in the dark...
Old Nov 8, 2003 | 01:30 PM
ivsleptsincethen
I found it. It was the shift lock pin. It broke and slide down. A 9 dollor part at autozone.
