Head bolts?
Old Jun 29, 2021 | 08:34 PM
argusp44's Avatar
argusp44
Head bolts?
I had wetness in my egr valve so I went to pull the oil cooler and on my way I found the egr cooler was bone dry and the exhaust ports from the front of the engine were wet whele the back ports were dry. I assume this exhaust comes straight from the cylinders so my first thought is a head leak, most likely the bolts.
Old Jun 30, 2021 | 08:36 PM
Mich6.0's Avatar
Mich6.0
So you pulled the intake and the ports your looking at are the intake valves if they are wet your truck was probably nosed down
Old Jul 1, 2021 | 05:36 AM
namnguye's Avatar
namnguye
I don't quite understand the problem. Is the egr cooler dry both ends, or one end is wet? If so, pressure test it or replace it, no head issue.
JTurbo
Aug 17, 2015 07:12 PM
Vinford
Mar 19, 2015 11:42 AM
joejackF250
Aug 6, 2014 01:46 PM
dieselpwr14
Jan 26, 2010 05:08 PM
05rattler
Jan 10, 2010 08:16 PM
