Remove 3.5 ecoboost coil pack
Old Jun 29, 2021 | 05:02 PM
983-over's Avatar
983-over
2013 F150 with 3.5 EB. Getting close to 50K miles (yes, that less than 6K per year). Time to change plugs. Removed 8mm bolt, unplugged connector. It seems that the boots are frozen on the plugs. Any tricks to pull coil pack without destroying ?
Old Jun 29, 2021 | 07:29 PM
257BEE's Avatar
257BEE
Just a little wiggle here and there should do the trick. The rubber boot is nice and snug to keep moisture out. Be sure to check the boots once you get them out and replace them if they are dried, cracked, or torn. Good luck, don't over think it though.
Old Jun 29, 2021 | 07:33 PM
ford390gashog's Avatar
ford390gashog
Well the boots have to get replaced anyway so pull them and twist.
Old Jun 29, 2021 | 07:42 PM
RLXXI's Avatar
RLXXI
Twist then pull once they break free. You should know if you just yank on them they will tear and leave you with a stuck boot piece in a very difficult place to extract.
Old Jun 29, 2021 | 09:22 PM
983-over's Avatar
983-over
OP here. Twisting and pulling was no joy. I was able to get a piece of parachute cord under the bolt down tang and the electrical plug. With the additional ability to pull and twisting it finally popped loose. Pulled the front plug on the passenger side and it still looks good. Gap was about .032 and the boot looks like new. Think I will just let it go for now. Thanks for your input.
Old Jun 30, 2021 | 04:19 PM
rbentnail's Avatar
rbentnail
I think if I had gone that far and had the spare parts in hand I would have gone ahead and replaced them. To each his/her/its own!
trike1946
Dec 10, 2017 12:42 AM
Cpriest
1997 - 2003 F150
Jan 10, 2016 06:46 PM
ltatkinson
EcoBoost (all engine sizes)
Dec 28, 2012 05:38 AM
ALL AMERICAN BOY
Modular V8 (4.6L, 5.4L)
Feb 26, 2012 12:11 PM
fireaxe
Jul 9, 2006 07:37 PM
