Kingpins
Old Jun 29, 2021 | 07:57 PM
DrCharles's Avatar
DrCharles
+9 degrees of caster will track great at high speeds. It will also quite noticeably increase the steering effort, and also compromise the handling in a corner (and tire wear) because when the steering wheel is turned, the tire will be tilted on its edge instead of sitting flat on the contact patch... I would have recommended +3 or at most +4 degrees.
On the other hand, our trucks are not known for cornering capability, and if you're happy with tire life and the way it drives, why worry...
Old Jun 30, 2021 | 12:59 PM
Thunderkiss1965's Avatar
Thunderkiss1965
I do have to lean into it to turn on the freeway, but I can also make a u-turn on the street with one hand. The front tires are wearing evenly. Maybe a little fast or it could be the inexpensive tires I'm running. I'm pretty happy with the way it drives. Maybe I have an acceptable contact patch because I am running 31X10.5x15's at 30 psi. It sticks pretty well.
ToddWTX
2015 + Expedition & Navigator
May 4, 2021 05:00 AM
savage2211
Delaware Chapter
Sep 12, 2010 10:53 PM
bill11012
Texas Chapter
Apr 28, 2010 07:18 AM
LaredoF350
Dec 14, 2009 11:59 PM
ChiefsFan
Kansas Chapter
Apr 8, 2004 06:08 AM
