1994 460 running rough
Old Jun 26, 2021 | 04:46 PM
obsxl's Avatar
obsxl
So my truck has done this a time or two over the last several months, but lately it’s become much more frequent. One minute it runs perfectly fine, then it will start running rough - low idle, running rich, and loss of power. It may run like that for a few seconds or 20 minutes. I have checked the engine codes a few times and have got codes 172 and 512. I will say the truck is probably due for a tune up, which I plan to do, but I don’t think the problem is a plug wire or a dist cap the way it comes and goes away. What would cause it to run like that intermittently?
Old Jun 26, 2021 | 05:31 PM
torq'ta 5 8's Avatar
torq'ta 5 8
miles? usually a crack in manifold, and very slowly gets worse over time, how old is 02 sensor, it could be time to change or its saying you have vacuum leak somewhere.
Old Jun 26, 2021 | 05:37 PM
SFaulken's Avatar
SFaulken
Yup, 460's are pretty legendary for cracking exhaust manifolds as they get older.
Old Jun 26, 2021 | 07:03 PM
obsxl's Avatar
obsxl
149,000 miles. she’s definitely got the exhaust leak on the passenger side, but it’s had it ever since I got it and always ran fine. I thought about a vacuum leak, but that wouldn’t seem to explain the intermittent running good and bad. I do plan to change the O2 sensor soon as well
Old Jun 26, 2021 | 08:26 PM
SFaulken's Avatar
SFaulken
if you don't fix the exhaust leak, two things are going to happen. you're going to burn a valve, and you're going to just keep eating oxygen sensors.
Old Jun 26, 2021 | 08:58 PM
obsxl's Avatar
obsxl
is it really that big of a issue? seems like every 460 out there has an exhaust leak, so you’d think more people would have problems like me. do you think it’s what’s causing the sporadic run rough?
Old Jun 26, 2021 | 09:10 PM
SFaulken's Avatar
SFaulken
They do have those issues, they choose to ignore them.
Old Jun 26, 2021 | 10:19 PM
obsxl's Avatar
obsxl
this issue is very hard to ignore, the truck runs like crap
Old Jun 27, 2021 | 05:45 AM
torq'ta 5 8
your crack has gotten worse over time, some people dont mind running like crap, most are the 'farm truck' frame of mind, and it'll be fine, 1 vacuum leak I had was green EGR vacuum line, and it was the length of the line(3/4" long) and it would take heat to make it worse, winter time 'meh...too damn cold to mess with...summer holy cow its hot...got to pick one to get it fixed, or (note to self-stop being a little b i )and fix it.
Old Jun 27, 2021 | 08:37 AM
obsxl's Avatar
obsxl
so I should replace my exhaust manifold hoping it will fix the problem? I dread the manifold bolts
Old Jun 27, 2021 | 10:26 AM
SFaulken's Avatar
SFaulken
That all depends on you. If you want to actually fix the problem, and do it right? Yes.
Old Jun 27, 2021 | 10:55 AM
Guitarjohnny's Avatar
Guitarjohnny
Gotta say my 94 F250 460 has had a passenger side exhaust leak for 16 years when it starts. It's the heat riser, goes away as soon as it opens. The truck runs great. I live in CA and the only time it failed CA smog was due to a bad plug wire. Trying to remove the nuts that hold the exhaust pipe to the manifold is guaranteed to result in broken studs and having to pull the manifold to repair and that's not my idea of fun. I guess I too have a farm truck mentality, but I'll let her leak a little.
Old Jun 27, 2021 | 11:32 AM
obsxl's Avatar
obsxl
man, you’re killin me here. not trying to be obstinate, but it’s hard to believe the common exhaust leak can be the only thing that causes it to run like that. do the manifolds usually crack or warp? I’ve heard they don’t use gaskets on them
Old Jun 27, 2021 | 11:36 AM
obsxl's Avatar
obsxl
I’m not worried about passing emissions or a little tick, but running like it is, is a problem lol. The almost certainty of broken exhaust studs is exactly what I fear
Old Jun 27, 2021 | 11:54 AM
kevinv10's Avatar
kevinv10
On my 94 460, had bad plugs. You would be surprised how much a new set of plugs, wires, cap and rotor improve the motor. Assuming that's your issue.
