C6 small leak on Drivers side...
Old Jun 24, 2021 | 03:12 PM
Flecker's Avatar
Flecker
Before I go off all haphazard like I figured I would ask WHAT is this plug? Am I gonna damage anything if I try to snug it up a bit?
I have a small drip coming from the threads on it... I'm not an auto trans guy.
Pic:
Leaking at plug... whats it for?
Old Jun 24, 2021 | 03:36 PM
dlburch's Avatar
dlburch
intermediate band adjustment.
Old Jun 24, 2021 | 04:10 PM
Flecker's Avatar
Flecker
What am I gonna hurt if I snug it down?
Never mind... I don't want to mess with it. Read to many horror stories about adjusting it, and mine is shifting fine. Will live with it.
Old Jun 24, 2021 | 04:33 PM
dlburch's Avatar
dlburch
you shouldn't cause any issues with trying to tighten the lock nut only (hold the center adjuster). If the locknut is tight, you will have to replace it...and you SHOULDN'T have any issues as long as the adjuster doesn't move.
Old Jun 24, 2021 | 05:59 PM
Flecker's Avatar
Flecker
Gotcha... Thanks man!
Old Jun 25, 2021 | 08:57 AM
headloct's Avatar
headloct
The lock nut is actually a one time use only piece that has sealant applied from the manufacturer. Get a new nut and like dlburch says,hold the adjusting screw in place and spin the lock nut off,install the new one. So easy,a cave man can do it.
Old Jun 25, 2021 | 10:50 AM
DB429SCJ's Avatar
DB429SCJ
Check with a local transmission shop.They should have one.
jonezzzman
Jun 21, 2020 12:39 PM
Laggy
May 13, 2020 08:58 PM
rews2
Mar 19, 2015 05:23 PM
Art5
1978 - 1996 Big Bronco
Oct 23, 2013 03:51 PM
