Smog delete
Old Jun 24, 2021 | 02:28 PM
Bvretn1's Avatar
Bvretn1
Smog delete
I have an 1988 F250 5.8l with rotted smog lines, so figured I'd remove everything. Per post on here and other forums, everyone said to get the A/P idler from Ford (Part# M-8604-A50) and a Dorman idler pulley (Part# 419-644). No need to change belts with this configuration...so they said. Well now the serpentine belt is way short to the point it still doesn't go on even with the tensioner fully disengaged.
Has anyone else done this? Did you have to change belts and if so what size?
Old Jun 24, 2021 | 03:34 PM
torq'ta 5 8's Avatar
torq'ta 5 8
You could gut your smog pump, and it becomes an idler, my buddy did on his 89 F250, 5.8L and kept his factory belt, been running 6yrs.
Old Jun 24, 2021 | 09:09 PM
nc73's Avatar
nc73
I have a 96 with the 5.8 and I just eliminated the idler and got a shorter belt and also eliminated the whole smog pump. Not sure if it's the same as your truck. There's a pic somewhere on the net of the new belt routing.
Old Jun 25, 2021 | 11:09 AM
wwhite's Avatar
wwhite
Here is a post I just updated with pictures and options.
https://www.ford-trucks.com/forums/1...l#post19820413
The only difference is mines a 1994, yours is 1988.
If the doorman pulley, 5.2", is that the same size as the Air Pump pulley?
Maybe wrong pulley in package.
Did the bracket come with a pulley? Is it smaller?
That is usually what happens, take off air pump, and install bracket that comes with a smaller pulley, now you need a smaller belt.
Did you put a brand new tensioner on?
Did you get a new belt, stock for what the truck should have?
Is the belt routed correctly?
If the only thing that has changed is the Air Pump pulley, and your belt is too tight, then the pulley is too big for the belt size you are running.
LadderDogV10
Jul 18, 2021 04:46 PM
baddad457
Jun 2, 2012 01:56 PM
Jrock909
Mar 8, 2007 07:28 AM
df150
Dec 23, 2003 09:56 PM
df150
Dec 23, 2003 08:03 PM
