Oil leak?
Old Oct 30, 2003 | 02:12 PM
philn's Avatar
philn
Question Oil leak?
My '02 with 52K seems to be leaking oil from both heads toward the rear. Can't tell if it's the covers or head gaskets but it seems to be getting worse. Anyone have the same problem and is this common? I'm still under warranty but hate to have Ford work on it. It's a crap shoot as to whether or not they will fix it right or cause more problems. A little oil doesn't bother me, but it's starting to leave drip marks on the driveway and that's when I get a little more concerned with it. Thanks!
Old Oct 30, 2003 | 04:21 PM
International Tech's Avatar
International Tech
check the High pressure oil rail plugs on both heads. alot easier and cheaper to replace if they are the problem.
Old Oct 30, 2003 | 04:31 PM
philn's Avatar
philn
Ok, thanks a lot International Tech.
