Replacing plugs...any tips?
Old Jun 21, 2021 | 11:29 AM
jrpitdog's Avatar
jrpitdog
So I am going to be doing, plugs, wires, cap and rotor. Are there any particular tips or tricks getting to the plugs, or is it fairly straight forward? Anything I should just go ahead and remove right away for access? I have an 89 250 with a 460.
Old Jun 21, 2021 | 12:14 PM
rla2005's Avatar
rla2005
I find it easier to get the passenger side plugs out from underneath. Usually too much emission tubes to get them from above. I have also had good luck going in through the passenger side wheel well. There is a small gap between the frame and inner fender assembly. A long extension or two with a swivel works well.
Old Jun 21, 2021 | 12:20 PM
jrpitdog's Avatar
jrpitdog
Thanks, I will take off the passenger tire to start off with.
Old Jun 21, 2021 | 12:30 PM
sandymane's Avatar
sandymane
Don't trust the plug gap out of the box. Recheck the gap for .044. Label plug wires so they are put back in in order and on the dist,.cap and try not to cross any wires. Putting a piece of rubber hose on the plug tip helps from dropping the old plugs when removing and for not dropping or cross threading the new ones to start them.
Old Jun 21, 2021 | 12:39 PM
jrpitdog's Avatar
jrpitdog
Thanks, I like that idea. I already looked up the firing order and cylinder numbers just in case
Old Jun 21, 2021 | 12:54 PM
jtab's Avatar
jtab
Clean out the plug wells before removing the old plugs to keep dirt out of the cylinder.
Old Jun 21, 2021 | 08:15 PM
kevinv10's Avatar
kevinv10
If the plugs have been in for a while, try to tighten them first. This helps to break up any issues of them corroding to the heads. Then loosen them. A trick i have learned over the years on many different motors.
anthonym92
25
Sep 20, 2015 08:09 PM
2pfspiff
Sep 13, 2007 02:41 PM
Nightrain
Jul 14, 2004 03:06 PM
pr
Apr 9, 2001 12:43 PM
