Speedometer problems
Old Jun 19, 2021 | 07:03 AM
Jesse lynn's Avatar
Jesse lynn
Does anybody know exactly what would cause my speedometer to max out when only going 5 mph or so. Also my odometer stopped working at the same time and says error. I just got my transmission rebuilt and I need to have this fixed due to the trans and the speedometer not working together properly thanks!
Old Jun 19, 2021 | 07:19 AM
subford's Avatar
subford
What is the conversion constant set to?
If it was set at 1.0 that would do it.
If not that you more than likely have a bad PSOM.
Conversion constant set to 1.0:
Attachment 279754
Old Jun 21, 2021 | 11:19 AM
wrongway01's Avatar
wrongway01
PSOM is most likely dead. I just ordered one for my truck 20 minutes ago from Module Mechanics in Florida. I was having hard shifting issues and ran all of the diagnostics that I could find. Speedo worked perfect but signal wasn't being transmitted to ECU. I'll know in a day or two if that's the issue, I'm reasonably confident that it is.
Old Jun 25, 2021 | 01:55 PM
Gord's-Fords's Avatar
Gord's-Fords
What is a PSOM? MY 95 SPEEDO IS BOUNCING ALL OVER WHEN ABOVE 70 KMH/45 MPH AND TRANNY BANGING SHIFTS HARD. : REBUILT DIF, NEW V.S.S. (VEHICLE-SPEED-SENSOR). TRanny shop says nothng wrong with transmission, scatching my head, mechanic scratching his head. WTH?
Old Jun 25, 2021 | 02:45 PM
subford's Avatar
subford
A PSOM PC board:
Attachment 279742
Attachment 279743
Old Jun 25, 2021 | 03:15 PM
Gord's-Fords
FORGIVE MY KNOWLEDGE-VOID. ON THE BACK OF THE SPEEDO OR IN THE BOX UNDER THE HOOD?
Old Jun 25, 2021 | 03:41 PM
subford's Avatar
subford
It is inside the cluster enclosure.
The "SPEEDO" (speedometer head) plugs into the PSOM PC board.
Old Jun 25, 2021 | 03:56 PM
Gord's-Fords
: THANK-YOU.
Old Jun 25, 2021 | 04:51 PM
Gord's-Fords
K, NOW, CAN'T FIND ONE. LOCAL SHOPS SAY ITS TOO OLD, AUTO PARTS STORES SAY NOT AVAILABLE TO BUY. GOT ANY SUGGESTIONS?
Old Jun 25, 2021 | 07:24 PM
subford's Avatar
subford
Yes I get mine from pick-n-pull salvage yards.
Then copy my mileage and the trucks setup into the new PSOM.
Then set the change times to 6.
Old Jun 26, 2021 | 09:06 AM
rla2005's Avatar
rla2005
Shut off the caps lock then take a look here: https://modulemechanics.com/product/...epair-service/
Old Jun 26, 2021 | 12:53 PM
sswari's Avatar
sswari
Hey there SubFord, exactly how did you do this?
Old Jun 27, 2021 | 08:38 AM
subford's Avatar
subford
Deleted Deleted
Sent a PM.
rvpuller
May 29, 2019 10:16 AM
srsparky32
19
Jun 11, 2016 06:00 PM
Authenticraft
Apr 8, 2010 11:55 AM
