Squeaks!!!!
Old Jun 18, 2021 | 08:30 AM
Jamey Eaton's Avatar
Jamey Eaton
Squeaks!!!!
Has anybody solved the squeaking that occurs when the steering wheel is turned tight or when you shove the clutch pedal in? Or maybe my truck is the only one that does it?? It seems to be coming from the vertically mounted reinforcement under the dash
Old Jun 18, 2021 | 09:31 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Are you talking about this support? There are 6 bolts to the firewall and 2 under the lower edge of the dash. Also 2 that connect to a piece that is welded in. Maybe that welded in piece is the vertical one you are referring to? You might take a rubber hose or stethoscope to the area and see if you can isolate the squeek. Might not hurt to make sure the bolts are torqued to spec. I have 3 similar 1966 trucks and have not noticed any squeeking from that area on any of them that I can recall. One of mine has no clutch pedal (automatic) but on that one the steering column bearing makes some noise. I plan on replacing that since I have it all torn down.
Old Jun 18, 2021 | 12:21 PM
Jamey Eaton
Yes that’s the bracket. I will check it out, thanks
Old Jun 18, 2021 | 12:43 PM
TA455HO's Avatar
TA455HO
Lead Gopher
The clutch return spring under the dash that connects to that bracket - if there is one - can make a sort of noise as it extends against the force of the clutch pedal and as it relaxes back to it's resting state. The spring is often missing or never had one so take that with tongue in cheek.
Old Jun 18, 2021 | 05:52 PM
Vandy23's Avatar
Vandy23
My clutch spring always squeaks. Have tried several lubricants and alas it still squeaks. I just turn the music up louder!
Old Jun 18, 2021 | 09:19 PM
Jamey Eaton
There’s no radio in my truck, factory delete. Can’t decide wether to cut the dash or not
Old Jun 19, 2021 | 02:16 AM
Order and Chaos's Avatar
Order and Chaos
I know a few guys that preserved their uncut dash (or leaving the original AM radio in place) and installed the new stereo in the glovebox. Modern sound, original looks, and easy to convert back if needed.
Old Jun 19, 2021 | 02:30 AM
Christmas's Avatar
Christmas
You might want to check the steering column bearings.
Old Jun 19, 2021 | 01:34 PM
Jamey Eaton
I get the same creak from my steering column as I do my clutch pedal. The steering column is more if you wiggled the wheel up & down, not when you turn it
Old Jun 19, 2021 | 06:14 PM
Vandy23's Avatar
Vandy23
Agreed, certainly an option. Fortunately I already had a hole in mine, but I would check out RetroSound. Head unit looks original with minimal cutting and radio comes with all the modern options while looking totally original.
Old Jun 20, 2021 | 02:42 PM
FuzzFace2's Avatar
FuzzFace2
I have a non-Ford that has that spring and from the factory there was a sponge pushed into the center of the spring.
I would guess to keep the noise down?
Could take a dish sponge cut it a little larger than the hole in the spring and force it in.
Dave ----
Old Jun 22, 2021 | 10:43 AM
Thunderkiss1965's Avatar
Thunderkiss1965
I like the color scheme you have there. Coming along nicely!
Old Jun 22, 2021 | 04:46 PM
Vandy23's Avatar
Vandy23
Thanks! Actually that was an old picture. Here is final look
Old Jun 22, 2021 | 08:26 PM
Jamey Eaton
That seat looks awesome!!! I love the badging on the back rest 👍🏻👍🏻
K5BEAST
Dec 11, 2017 07:14 AM
f100jim
Oct 28, 2011 03:03 AM
fordff
Aug 7, 2009 09:29 PM
nighthawk285
Oct 25, 2006 02:12 PM
