O2 sensor source
Old Oct 30, 2003 | 08:06 AM
ksvtwin's Avatar
ksvtwin
O2 sensor source
Does anyone know the best place to purchase an affordable O2 sensor? have a '93 F150 with 5.0 and it is a 4 wire sensor. I've seen universal type.. would they work if they are 4 wire? thanks, KS
Old Oct 30, 2003 | 09:36 AM
jimandmandy's Avatar
jimandmandy
Autozone, Kragen/Checker, Pepboys chains are normally the places to shop for common tuneup parts like O2 sensors. Usually, one for a Ford is as cheap as the universal one and you dont have to mess with splicing wires.
How do you know yours is bad? Bosch, for one, tries to sucker the public into replacing them every 30,000 miles! Unless you have failed an emissions test or have a check engine light, it is probably ok. If you are getting 12-15 mpg and that has not suddenly changed, it is not the O2 sensor. That is normal poor mileage for a 5.0 in a truck.
Jim
Old Oct 30, 2003 | 10:58 AM
ksvtwin's Avatar
ksvtwin
I was just assuming it was bad. It has 240,000 miles on it and i figure even if it's within range, it's still probably not as accurate as a new one.
