Delete Cruise Control
Old Jun 11, 2021 | 09:08 AM
idiambulance's Avatar
idiambulance
My cruise control has never worked and honestly I never use it so im fine just getting rid of it. Im not sure which but I either want to install a transformer or a less likely a diesel heater where it currently is. Ive seen a ton of posts about repairing it but im curious what suggestions you have for just removing it all together. I gotta look closer but it looks like I should be able to connect the vacuum lines to each other and just delete everything else. I didnt have much luck finding a post strictly talking about removing it.
Old Jun 11, 2021 | 09:32 AM
tecgod13's Avatar
tecgod13
Plug the vacuum line that comes across the truck from the vac pump area. The other lines run from the brake and clutch pedal and don't matter. Unplug the electrical connector, disconnect and pull out the cable running the the injector pump lever. Then pull out the cruise unit.
The rest of the bits on the pedals and the module under the dash don't matter and won't harm anything.
Old Jun 11, 2021 | 09:48 AM
idiambulance
Based on what I had seen and read thats what it looked like. Just wanted to double check and make sure there wasnt a super secret component that i wasnt aware of. Ill update this post later with pictures. Thanks so much.
Big Orn
Dec 16, 2024 05:57 PM
Rustyol79
Sep 1, 2017 08:02 PM
dyoungen
Feb 20, 2011 03:44 PM
BKF250
Jan 25, 2010 11:27 PM
nelly781
1978 - 1996 Big Bronco
Jul 11, 2004 07:57 PM
