Still pinging
Old Jun 6, 2021 | 06:27 PM
joeriscky's Avatar
joeriscky
Still pinging
Bought a 95 f250 5.8w 5speed with a bad motor. Sourced a 1996 5.8w from a f150 and the thing runs great except for the pings. The original 5.8 was the SD setup but the new 5.8 was MAF setup. When i installed it i used the SD harness. Motor runs good but has engine ping at higher rpm. I have replaced the usual suspect but it still pings. See list below.
My question is there something I'm using from the MAF system that's effecting the motor cause it's run on a SD system(TFI or distributor....) ? I swear it pings more at 8 degrees of trimming then at 10 degrees. Its driving me crazy!!
I replaced plugs, wires, cap, rotor, coil, injectors, and even replaced the bad capacitors on the ecm. I also have tested the EGR and its working correctly...
Thanks in advance,
Old Jun 6, 2021 | 09:11 PM
Don Naslund's Avatar
Don Naslund
I would retard the timing more even to zero and test for ping. Ping happens on hard acceleration or pulling a load. If it still pings, I would try a higher octane gas. If it still pings, I would blame the timing chain.
Old Jun 8, 2021 | 05:51 PM
DaveMcLain's Avatar
DaveMcLain
I would check for a slipped balancer and or the wrong timing pointer. Remove the valve cover. If the left side is easier use cylinder number 6. Get the engine in split overlap with each valve open the same amount and then look at the timing marks. The engine should be at or very close to TDC. If not there's your problem.
Old Jun 8, 2021 | 08:07 PM
Conanski's Avatar
Conanski
Good chance the PCM is bad of it had leaking capacitors.
Old Jun 17, 2021 | 02:02 PM
motojoe35's Avatar
motojoe35
Are you checking the base timing with the spout connector removed?
Jpautoglass
Dec 8, 2019 11:52 AM
32-289
Mar 24, 2014 06:06 PM
japjb1
1997 - 2003 F150
Jun 25, 2006 04:24 AM
Lionsfan
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jun 11, 2004 11:01 PM
jams3
Aug 8, 2002 01:58 AM
