Truck broken down - electric problem
Old Jun 5, 2021 | 05:31 PM
trike1946's Avatar
trike1946
Question Truck broken down - electric problem
Hi on my 07, E350, all of a sudden the battery went dead. And the power lock switch is very hot. If I knew where the fuse or relay was, I could pull it and get the van back. But I don't know which it is. Does anybody know. Right now I disconnected the battery so it doesn't get worse.
Thank you.
Old Jun 5, 2021 | 09:23 PM
Franklin2's Avatar
Franklin2
Fuse #5 30 amp in the underdash fuse box supplies power to the door locks and the power windows. You could try that, but your windows may not work either. But that would narrow down the problem if that makes the drain go away.
Old Jun 6, 2021 | 05:34 AM
JWA's Avatar
JWA
I replied to this same member's question in the Full Sized Vans sub-forum:
Originally Posted by JWA
If you DO NOT HAVE Remote Keyless Entry (RKE) there is only one fuse: F5 @ 30a located in the Central Junction Box (CJB) aka inside cabin fuse box.
If you DO HAVE RKE there are 4 additional fuses: F2 @ 10a, F10 @ 20a, F15 @5a & F23 @ 20a.
You can find the fuse locations in the owners manuals which can be downloaded and saved here: Owners Manuals The fuse information begins on Page 170.
I add the RKE Info only because it could affect this "hot switch" issue. If possible to do a voltage drop test across any of those above-listed fuses we might be able to further narrow down which component is causing the problem.
Old Jun 7, 2021 | 04:49 AM
trike1946's Avatar
trike1946
Thanks Franklin. I got it back. I will try and figure it out.
Old Jun 7, 2021 | 04:50 AM
trike1946's Avatar
trike1946
Thanks JWA. I appreciate it. I will download the manual too.
trike1946
Jun 6, 2021 04:28 AM
ridetrains
May 17, 2021 11:22 AM
larspetter123
Aug 5, 2008 11:44 AM
Foamy
Aug 3, 2008 08:48 PM
toots
Jun 29, 2004 05:37 PM
