Sponsored by: Real Truck
removing a rear leaf
Old Oct 29, 2003 | 09:24 PM
bigskyllc's Avatar
bigskyllc
Has anyone removed a rear leaf on F250 or 350 4x4 to level the rear with the front. What about putting some low profile 22 or 24's. I'm contemplating this but have only seen a couple trucks on the road with this look. Obvoiusly most people lift these trucks but I load motorcycles in and out on a daily basis and would like to have a lower tailgate height without compromising too much ground clearance etc. I'm not a big offroader but need the 4x4 for ski trips, pulling the boat out and stuff like that.
Any pic's or ideas???
Old Oct 29, 2003 | 09:35 PM
wolfmanagh's Avatar
wolfmanagh
I had to look only a little bit for this one, I saw something like this in a snowmobile catalog. http://www.tkloader.com/
Old Oct 29, 2003 | 10:30 PM
bigskyllc's Avatar
bigskyllc
Wolfmanagh,
That's interesting but it's a little more involved than I want to get, I need the back of my truck for other normal day uses also. Thanks for the reply though.
Old Oct 30, 2003 | 12:02 AM
SouthernDually's Avatar
SouthernDually
Question Lowering
Have you thought about either a airbag system or just putting some smaller blocks in.
Old Oct 30, 2003 | 08:09 AM
bigskyllc's Avatar
bigskyllc
Hadn't thought of that but smaller blocks would probably do the trick pretty inexpensively huh...
Old Oct 30, 2003 | 09:44 AM
Waxy's Avatar
Waxy
If you have an F350 it came stock with 4" blocks, you can get the stock 2" blocks from the F250 for around $40 I think.
Most guys on this board raise the front to level the truck, lowering isn't the "thing" around here.
I wouldn't mess with the rear spring packs.
An air bag system would be the ticket, but it's a pricey ticket.
Waxy
Old Oct 30, 2003 | 03:18 PM
bigskyllc's Avatar
bigskyllc
Thanks.... I like that idea, I'm going to look into it. If it doesn't work out I'll raise the front to get it leveled out like you mentioned is the popular thing to do and probably better for re-sale too.
Old Oct 30, 2003 | 04:00 PM
1BADF350_4XCREW7.3's Avatar
1BADF350_4XCREW7.3
Maybe talk to your local 4WD shop, a lot of guys with F-250's are looking for the taller 350 block to go with a leveller kit for a small lift and would probably swap you if the shop doesn't have a pair handy.
I have a buddy in Payson right now who'd swap you in half a blink.
