heat not coming on
Old Oct 29, 2003 | 08:57 PM
88bronco351's Avatar
88bronco351
heat not coming on
I have a 88 bronco and when i start the truck and turn on the heat it does not blow then when i start down the road it comes on but it does not blow hard at all like it is on low when it is on high and it is not hot at all any ideas ........... any help thanks
Old Oct 29, 2003 | 10:45 PM
BRI-GUY74's Avatar
BRI-GUY74
Check to see if the fan is blowing w/o moving and check to see if your thermostat is working or just stuck open.
Old Nov 3, 2003 | 05:51 PM
wolfen's Avatar
wolfen
Hi 88bronco351,
If the heator is not properly grounded or has a power/ground fault you will end with these symptoms!
Also follow BRI-GUY74's suggestion about the t'stat!
________________________________________________
‘90 Ranger XLT: 2.3L, EEC-IV, EFI, DIS, 2wd, Mazda 5sp
