Electrical question
Old May 31, 2021 | 07:46 AM
Snowturtle's Avatar
Snowturtle
Electrical question
I posted this over in the regular truck forum because it’s not IDI related but decided that you diesel guys have always had the answers so came back here.
I recently replaced my beat up bed with a flatbed and added an after market EGT and boost gauge to my truck. Since then, or maybe it started before and I didn't notice, my taillights are getting a low voltage current and are dimly on anytime I have the key on. My best test point is my trailer plug. I am also getting a low current on the trailer brake contact so I thought I had it figured out. I tried disconnecting the trailer brake controller and pulling the 30 amp fuse in the power distribution box. Neither of those fixed it. I unplugged the taillights in the flatbed (standard trailer lights set in to holes in the back), still no dice. I disconnected my new gauge, no dice. I disconnected the trailer plug from the harness at the back, lights still on. They are not on as bright as when the headlight switch is on or the brakes are on. Any ideas where I could be getting stray current?
Old May 31, 2021 | 08:13 AM
tjc transport's Avatar
tjc transport
i ain't rite
bad ground.
Old May 31, 2021 | 09:41 AM
Snowturtle's Avatar
Snowturtle
Originally Posted by tjc transport
bad ground.
Sounds hard to find! But I'll go looking. Thanks
Old May 31, 2021 | 10:44 AM
tjc transport
i ain't rite
each light should have three wires. one for blinker/brake, one for running light, and one for ground.
the ground wire either has to be directly to the frame, or body if it is metal. the the frame needs a ground strap from the battery. body needs a ground strap to the frame.
Old May 31, 2021 | 10:56 AM
Snowturtle's Avatar
Snowturtle
I'll double check all that. Thanks
Old May 31, 2021 | 02:03 PM
tjc transport
i ain't rite
and if the lights have reverse lights in them there will be 4 wires coming out of the light.
Old May 31, 2021 | 06:17 PM
jjqllc's Avatar
jjqllc
Put a ground strap from the body to the frame.
Old Jun 15, 2021 | 02:52 PM
Snowturtle's Avatar
Snowturtle
Solved!
I learned something today! My problem was that the trailer lights I put in my flatbed were LED and did not offer enough electrical resistance. Swap flights out for good old school bulb type and the problem is solved
Old Jun 15, 2021 | 03:27 PM
tjc transport
i ain't rite
led's will do that. never thought of the fact you were running led's.
i have led 's on 2004 the rack body, but also have a set of regular round style lamps mounted to the frame.
Snowturtle
May 31, 2021 08:10 AM
Rancholago
All Things Towing
Aug 3, 2020 10:46 AM
oldrifleman
2009 - 2014 F150
Apr 28, 2015 12:17 AM
nitro3421
32
Apr 9, 2012 09:45 PM
riggz
Apr 25, 2007 08:28 AM
