Tire rubbing issues
Old May 30, 2021 | 06:04 PM
Jerseyboy1983's Avatar
Jerseyboy1983
Tire rubbing issues
Hi everyone. I just installed a 2.5 inch leveling kit on my 2020 f250 2wd. And new 35 inch tires. All was great until I did first uturn and realized in rubbing. When I looked underneath, it looks like I'm rubbing on my sway bar. I prefer to not use wheel spacers as I heard bad things about them and I can't afford offset wheels right now. Any ideas? Any way to move my sway bar? Or maybe an aftermarket swaybar made for this issue? I'll be towing a camper soon so I need to make tight turns. If offset wheels are my only safe option, how much offset do I need to clear the swaybar?
Old May 30, 2021 | 07:47 PM
brmpipes's Avatar
brmpipes
The after market sway bar isn't cheap either.
Old May 30, 2021 | 07:58 PM
Mainebucks's Avatar
Mainebucks
Turn the music up and drive.
Mine rub a little also. So, did my old truck. I just back off when I hear it. Of course if it causes big problems at a campground with your trailer or something then I guess you would have to address it. I think mine is rubbing on the front air deflector, I haven't bothered to check further into it. Good luck.
Old May 30, 2021 | 08:00 PM
Section179's Avatar
Section179
You’re probably only loosing a few percent of your turning radius. A little rub on the sway bar won’t hurt anything. I’d live with it if you’d rather save your money.
when I put 37s on my 4wd the rubbing started a couple of degrees before the limit. The rub was an irritation more than a real harm or impact on ability to turn tight.
Old May 30, 2021 | 09:10 PM
Jerseyboy1983
The campground is my biggest fear with all the tight turns. It rubbed so bad the other day I could smell the burnt rubber smell.
Old May 30, 2021 | 09:11 PM
Jerseyboy1983
How do you feel about hub centric wheel spacers?
Old Jun 1, 2021 | 11:40 AM
Jerseyboy1983
Do you know where to get one if i was to go that route?
Old Jun 1, 2021 | 12:22 PM
brentadams646's Avatar
brentadams646
I thought the smallest hub centric wheel spacers you could get that were 1) a quality made part, and 2) didn't require hacking off the stock wheel studs - were 2" spacers? I could be wrong.. I refuse to run spacers on a truck of this size, but I know others do it all the time. Just a matter of opinion personally.
Old Jun 1, 2021 | 01:16 PM
Jerseyboy1983
I found smaller from Bora that were smaller and still hub centric. But im not sure if that will stop the rubbing on the sway bar. So if i go that direction, id stay with 2 inch and trim off what is needed if it rubs the wheel well area.
Old Jun 1, 2021 | 03:40 PM
GABAR's Avatar
GABAR
Do it right by doing it once.
Save up for the correct offset wheels and until then, do multi point turns so as not to hit the swayback or reduce your tire size.
Old Jun 1, 2021 | 08:57 PM
Jerseyboy1983
That's what I decided on tonight. I'm going to spend the money and buy some -12mm offset wheels and be done with it.
jnuechte
Apr 30, 2022 09:51 AM
AmLS28
Mar 12, 2020 12:13 AM
LiquidSteam
Apr 13, 2019 02:42 AM
adam10
Aug 17, 2014 11:33 AM
AllMuscle03
May 2, 2010 03:01 PM
