Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Flow Bench?
Old Oct 29, 2003 | 07:49 AM
dfisher1's Avatar
dfisher1
Flow Bench?
Can I build a flow bench? One for carbs? One for heads? has anyone ever asked this on this site before? This sure would come in handy for jet setup.
KingFisher
Old Oct 30, 2003 | 07:49 AM
dfisher1's Avatar
dfisher1
All,
Let me elaborate a little more: Often enough each carberator has its own characteristics. Each motor has its own displacement. This means, that ideally, every caberator must be tuned/adjusted to meet its desired application. Ergo, a flow bench. This is simply a test stand which can simulate the volume flow conditions of a specific motor. It's an adjustable vacuum. This in turn, allows the tester to measure the pressure drop across the jets and diffusers and thereby select the correct jets to optimize carb setup.
Secondly, heads can be a pain. with a flow bench you can insure that each cylinder flows the same volume with the same head loss. This is high speed, in my opinion. I'm just not sure what the industry uses for controls and measurement devices.
I'll contribute more later,
KingFisher
Old Oct 30, 2003 | 07:55 AM
Pilgrim's Avatar
Pilgrim
dfisher1:
Sorry I can't give you a more detailed answer, but I remember a few years back (5,6,7???) there was a series of articles in one of the performance mags on "how to build a flow bench". I think it was Hot Rod or Popular Hot Rodding. You might be able to find it with a search or through one of the mags websites. Hope this helps.
Pilgrim
Old Oct 31, 2003 | 08:50 PM
angus's Avatar
angus
Here you go:
http://www.ag.auburn.edu/users/gparm...es/flowbench2/
I just searched for "Popular Hot Rodding" and "flow bench" and voila. Faster than going into the basement to look for the back issues.
Old Nov 1, 2003 | 07:41 PM
ctfuzzy's Avatar
ctfuzzy
Holy COW. How can you not just treasure this place and it's citizens!?!?!
What a great bunch of folks !!
(sorry for the rant)
Old Nov 1, 2003 | 10:49 PM
Torque1st's Avatar
Torque1st
Posting Legend
I love it when a plan comes together
Old Nov 3, 2003 | 09:55 AM
dfisher1's Avatar
dfisher1
Gentleman,
Thanks for the foot work. This should get the job done.
Great thanks,
KingFisher
