Sponsored by: Real Truck
running boards
Old May 28, 2021 | 07:35 PM
chmoore2's Avatar
chmoore2
running boards
new to the site. i just bought a 2016 super duty with no running boards. will running boards from a 2017+ fit on my 2016?
Old May 29, 2021 | 12:00 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
The brackets to the 2017+ Super Duty are entirely different than the brackets to the 1999-2016 Super Duty.
The good news is that 1999-2016 actually began production at the beginning of 1998, and therefore offers 18 production years of choices in running boards that actually will fit without issue.
Old May 29, 2021 | 01:12 AM
chmoore2's Avatar
chmoore2
10/4, thanks for the info!!
Old May 29, 2021 | 10:45 PM
nbonci's Avatar
nbonci
I went with GoRhino RB20. They are style after the Raptor, heigh and tight. Big appeal for me was that they not only block rocks and road projectiles, but the stick out further than the body. So if someone decides to swing open their car door next to you, they will hit the running boards and not the truck.
Old May 30, 2021 | 12:45 PM
bwguardian's Avatar
bwguardian
Yes they will fit, you will just have to mount them with the older 2016 down brackets. I did the same thing on my 2000 F350 with 2018 up extended running boards. People kept telling me the same thing on here a couple months ago...that it couldn't be done, well here you go...
Old May 30, 2021 | 10:31 PM
PJWhelan's Avatar
PJWhelan
BWGuardian: I want those!! I have a 2002 F250 CC XLT. How much were they? My originals are kinda banged up and I wonder about some rust spots under the doors. I believe the OEM used 4 brackets. You think you could snap a pix of the mount under the door area? Those are exactly something I could use..
PJ
Old May 31, 2021 | 12:07 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
With enough time and talent, anything can be customized for mere money and materials.
The retrofit of the 17+ running boards with 1999-2016 brackets shown by bwguardian looks great...
But the extended portion is missing the supporting structure that prevents the aft portion of the step to access the bed from bending downward when used.
That support structure looks like this:
(Photo by xxxsherpa)
Old May 31, 2021 | 10:16 AM
bwguardian's Avatar
bwguardian
PJ
I paid $200 for them, and there are other sets locally around here for about $250...there are fewer of the extended version. I guess most are wanting the power folding units like AMP Research has and now Ford has them as an option...which is why these are no longer available from Ford. I like the looks of the power folding units but there is alot of support harnesses and such for them...plus I've not heard good things about them when you get them off road in the nasty stuff.
Old May 31, 2021 | 10:25 AM
bwguardian's Avatar
bwguardian
The newer Ford factory running boards with the extension use three brackets...one of which is the one pictured for the extension. The newer regular Ford factory running boards without the extension use only two brackets. The older factory Ford running boards use three mounts as pictured in mine above. I'm okay with not having that extension support for several reasons, but the most important one is I've tested it and it's fine without it.
Old Dec 27, 2025 | 02:21 PM
Spiderlady's Avatar
Spiderlady
1st Gear
Running boards and brackets
I’m wanting to change my running boards on my 2012 f150 xlt supercab. They are too close to my truck and I want to have some lower and out a bit further. Also which years of the f250 and f350 will fit? Thanks
Old Dec 29, 2025 | 03:43 PM
Overkill2's Avatar
Overkill2
Great job... love the built not bought attitude...
I did not know Ford made wheel to wheel running boards. Might have to look into that.
I want to go with Ranch Hand's wheel to wheel running boards but would scuff them up and have them sprayed with bedliner... looking at Bullet Liner, they developed Line X, sold it off then started Bullet Liner later...
But have to admit, I like the look of those 18 running boards... thanks for posting up.
Old Dec 30, 2025 | 01:07 PM
bwguardian's Avatar
bwguardian
Thanks, been thinking about moving on to some electric power steps now...
Old Dec 31, 2025 | 11:29 AM
Overkill2's Avatar
Overkill2
Nice... and clean truck as well. Good luck.
jamlam1
Jun 11, 2019 01:11 PM
Corner Gas
Apr 7, 2010 08:37 PM
