I made the mistake of letting the system install sync upgrade version 3.4.21020, now none Of the Sirius Travel Link functions work, they all show as “Not Available”. Searching on line I am finding lots of posts in various forums that this problem is common, so if you can avoid it until they get it sorted out I would. I am really sorry I didn’t stop it from installing by turning off the OTA updates.
There is a newer version available, but you will have to use the CyanLabs updater to do it. I've not checked to see the functionality of TravelLink since updating FWIW.
I installed the latest version last night with cyan labs, the travel link functions showed unavailable until I performed a master reset.
After this everything appears to be working fine.
I did a master reset as well, it worked, then it didn’t again. Same behavior has been reported on the f150 and Lincoln forums. Right now it is a mess, my clock also started doing odd things, off by an hour, even if you synchronize to GPS. Seems to have lost the concept of DST, even though that box is checked.
I'm running v3.4.21020 and Travel Link loads fine. I typically don't use it but it is functional under this build. I used CyanLabs for my update. Not sure I'd be totally upset about Travel Link not working as it not a real beneficial tool.
That's interesting. I updated a good two weeks ago or so to 21020. I noticed some different things in the Sirius screen with an old-school-looking button like a manual radio to enter a specific channel, but noticed this morning that my clock was off by +1 hour. It hadn't been prior to this morning, but I also did make a bunch of changes with Forscan yesterday.
